40-дюймовый LED-телевизор Vu без функций Smart TV
How do I connect a 5.1 speaker system
how do i connect a 5.1 speaker system on this tv?
as the TV has only co-axial and Headphone jacks.
I have an F&D speaker system
http://www.amazon.in/gp/product/B00E2OY9...
Please reply.
Это хороший вопрос?
Счет 2
2 Комментариев
how do I select external speaker option in VU 43bu113 TV
из
Vutv 32bfm model how to connect 5.1 speaker please explain
из
Добавить комментарий
1 ответ
Выбранное решение
Best option to connect 5.1 home theatre from your TV is to connect through the Digital out COAX output jack at back of your TV but you will require either Digital to Analog Converter or 5.1 converter which you can buy from Amazon. In case you want to connect from your headphone jack out from your TV you can connect through 3.5 mm cable to RCA AUX cable to your home theatre but the sound will be only 2 channels LEFT RIGHT channel out only and low so you can better buy an amplifier for the same.
Был ли этот ответ полезен?
Счет 0
4 Комментариев:
same problem for me in vu 32D6475. how to connect 5.1 home theatre? step by step pls guide
из
IAM also facing same issue in vu32, please explain
из
My problem solved by fixing of coaxial to RCA convertor to digital out pin in a tv
из
I have issues for connecting speakers with Vu TV please help and guide for connecting the speaker to TV
из
Добавьте свой ответ
Anjan gogoi буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 15
За всё время: 22,065
