Samsung NaviBot SR8855 — это удобный робот-пылесос от компании Samsung.
Short shift and turn.
Navibot sr8855 after repair of FET tranzistors for brush have bad mooving - navigation.
From the beginning it worked well and after some time was problem in navigation.
It looks like that: move 20-30cm stop and go back about 3cm, turn 90st. and repeat.
Sometimes work good for 1 minute and then again fail to this state.
I try test mod and all sensors look fine, motors are OK too.
Это хороший вопрос?
Счет 2
1 Комментарий:
I have the same issue. Is there a fix?
из
Добавить комментарий
5 Ответов
Hi,
yes, i found that it was dusturbation in system . I add some capacitors on motor and all is OK
Был ли этот ответ полезен?
Счет 0
Can you describe more precise what did you done?
Could be the aging of the accumulator?
Счет 0
I must replace suction motor and with it start the disturbance of electronics. For this I used capacitors on motor pads. I was 1nF + 100nF + 1uF together. To other motors must be carefull becouse are PWM drivered. There You can use only some smaller - max 100nF capacitors.
Счет 0
1 Комментарий:
Hi
What voltage do you use in capacitors?
из
Can be that the battery started to decay?
Счет 0
It could probably have an effect but it is not a reason.
Счет 0
Добавьте свой ответ
smsoftware буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 24
За все время: 2,313
