Sony Xperia J — это простой смартфон, работающий на программном обеспечении Android.
Problem with network signal
I have a problem with my network signal.
I opened phone and found out that the connector from the second (lower) board has broke.
By the connector i mean the one that has a screw hole in it, its by the vibration mechanism.
picture of the board
So i would like to know if that's why i don't get network signal, or should i investigate more?
Это хороший вопрос?
Счет 2
Добавить комментарий
3 Ответов
Do you mean this connector?
If this connector is broken you may have a problem with network signal strength. You need to solder it or replace this subboard. A good idea is the replecement of the rf cable (a black cable connected to this subboard).
Был ли этот ответ полезен?
Счет 0
The problem that you state.have different problem with mine situation
Счет 0
It seems that the RF connector is damaged...kindly look at the condition maybe that is the reason and you need to replace.
Счет 0
Добавьте свой ответ
filerzr буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 10
За последние 30 дней: 23
За все время: 3,189
