Sony Xperia Z — смартфон на базе Android, выпущенный в 2013 году. Это один из самых крупных смартфонов в линейке Xperia с 5-дюймовым дисплеем Full HD. Номера моделей: C6603/C6602.
Adhesive will not stick
I just fixed a Sony Xperia Z and after a little while the adhesive does not want to hold the screen in some places. Do i need to buy a better adhesive?
Это хороший вопрос?
Счет 3
1 Комментарий
I have used kitchen silicone. I have changed this phone display 3 times works every time :)
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
This seems to be a big issue with S5's and Sony Experia's. Best thing to do is to make sure you thoroughly clean frame, apply a plastic adhesive activator and use high quality adhesive's. Also you need to check your frame/chassis for damage, separation, and or whether or not its bent. We've been looking for a supplier for Sony Experia OEM water proof adhesive. If anyone knows where to get it can you please let us know. Thanks
Был ли этот ответ полезен?
Счет 1
heat it up with a hair dryer carefully, then put it on its back facing down, put a little weight on the top and leave to set. as mentioned above make sure the bezel is clean from the old adhesive, there is a glue that does help called B7000 we sell this on our site and its a great glue for this type of job, not corrosive like superglue and its flexible at the same time.
Счет 0
1 Комментарий:
Glue B7000 where can i find it, i can't find it on his site
из
Добавьте свой ответ
heljar97 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 876
