ho do I change language
how do I change language back to english.somehow it changed to a foreign language
Это хороший вопрос?
Счет 1
1 Комментарий
where is the menu button?
из
Добавить комментарий
3 Ответов
Выбранное решение
Go to the main menu—Disconnect your iPod from your computer, then press the Menu button until the menu title says "iPod," regardless of the language displayed. This means you are at the main menu.
Select your language.
If you have an iPod nano or Fifth Generation iPod (iPod with video):
Scroll down to the last menu option but don't select it.
Scroll up one menu item. This should be Settings.
Press the Center (Select) button. This takes you to the Settings menu.
Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
Scroll up to the third menu item from the bottom one. This should be Language.
Press the Center button to select Language.
Select your preferred language from the list.
http://support.apple.com/kb/ht1824
Был ли этот ответ полезен?
Счет 4
1 Комментарий:
For my nano 3rd generation, on the top menu, 3rd from the bottom was settings, then on next screen, third from bottom is language
из
the fastest way is to restore it with itunes. back up your media and click on the restore button
Счет 0
1 Комментарий:
but where is the menu button, I only see 6 icons?
из
The directions look great but I can't even find the settings menu. Pressing the center button at the bottom does nothing but make the icons wiggle.
Счет 0
Добавьте свой ответ
pete буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 22
За всё время: 12,829
