Moto G — это доступный по цене смартфон от Motorola. В нем есть все функции, которые можно ожидать от смартфона, за полцены. Номера моделей: XT1032, XT1033 и XT1036.
Why is part of my replacement screen unresponsive?
I recently replaced my Moto G's screen with one I found on Amazon.com. For awhile (about 48 hours) it was working flawlessly. Then it started misbehaving. I noticed the touch screen responding poorly. I narrowed it down to one horizontal section of the screen just under the center as unresponsive. I downloaded a touch-test app and confirmed this was the case. However, this is not a permanent condition, as the area sometimes works randomly and other times is completely unresponsive.
Thinking it might be a loose connection, I took my phone apart again and checked the connections. I took the ribbon cables out and put them back in again after cleaning with alcohol. The problem persists.
What could be causing this dead section of my touch screen? And is there a way to fix it?
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Выбранное решение
Its possible the screen is defective, get a replacement and see if it does the same thing.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Peter Pollet буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 14
За всё время: 1,610
