Модель A1419 / EMC 2806 / конец 2014 г. или середина 2015 г. Процессор Core i5 3,3 или 3,5 ГГц или Core i7 4,0 ГГц (ID iMac15,1); EMC 2834 конец 2015 г. / процессор Core i5 3,3 или 3,5 ГГц или Core i7 4,0 ГГц (iMac17,1). Все модели оснащены дисплеем Retina 5K.
HDD Upgrade/Replacement with SSD?
Hi, I have the newest iMAC 27inch Retina 5K 2015 it came with 1 TB SATA Disk. Wondering what the options I have to upgrade/replace the drive for SSD. Can I add as 2nd hard drive or i need to remove SATA disk and install my SSD. If so what kind of adapter I need?
Это хороший вопрос?
Счет 9
1 Комментарий
How would you replace the hdd with double ssd setup using the 2.5->3.5’’ double ssd adapter namely Corsair Dual SSD Mounting Bracket 3.5" CSSD-BRKT2 ?
из
Добавить комментарий
8 Ответов
Выбранное решение
Your system has two storage connections 1 SATA 3.5" HD & 1 PCIe SSD blade drive.
To start with the newer 'Thin Series' systems are much harder to open and if you are not careful you can easily damage the display which would be an expensive mistake! Carefully review the IFIXIT guides and make sure you use the correct tools (don't substitute).
As to your choices here, yes you could replace the 1TB HD for a SSD. You will need to get a 2.5" to 3.5" frame and you'll need this adapter cable: OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later as you need to replace the thermal sensor for the SMC services from running wild without the HD input. You see, the SSD does not have the needed sensor, the in-line adapter cable replaces the missing sensor.
If you just bought the system you may want to see if you can exchange it for a SSD model, then add in a HD configuring the system as a Fusion Drive. That way you gain the space of the HD but also have the speed of the SSD.
Update >> 8/7/15
The Blade SSD is mounted on the other side of the logic board and requires a lot more work to put in. So far no one offers the custom Apple part. Which is why I was recommending you exchange out your system if you can with a SSD model.
Review these IFIXIT guides to see the differences:
We suspect the Apple iMac 5K SSD is a custom 2 lane PCIe-3 SSD blade drive (Apple hasn't disclosed the SSD it uses spec's).
Here's a good reference on what you could get with a SSD PCIe drive Vs SATA drive. Intel’s 100-series chipsets: DDR4, PCIe 3.0 SSDs, and other Skylake supplements, review the section: PCI Express 3.0, and what it means for SSDs
iMac Intel 27" Retina 5K Display Жесткий диск Изображение
Инструкция
Замена жесткого диска iMac Intel 27" Retina 5K
Сложность:
Умеренно
1 - 2 hours
iMac Intel 27" Retina 5K Display SSD-накопитель формата blade Изображение
Инструкция
Замена SSD-накопителя формата blade в iMac Intel 27" Retina 5K
Сложность:
Сложно
2 hours
Был ли этот ответ полезен?
Счет 8
9 Комментариев:
Dan, thanks for reply, if I decide to keep SATA drive and add PCIe SSD blade drive do i need to purchase the adapter cable for thermal sensor? Also what type of SSD blade drive will fit?
из
Only the SATA drive connection requires the custom cable. The PCIe connection don't not have or use a thermal sensor (SSD's just don't get that hot needing extra cooling).
из
Dan, finally I decided to go with PCIe model SSD and keep my 1TB sata as 2nd volume. I searchee but couldn't find any PCIe SSD for my model. The only place i saw couple is on ebay but not sure which one is for my iMAC Retina 5K mid2015. Can you help me? Was looking for a 256GB. Also i see that there are SSUAX type and SSUBX.. A lot of question i know :))
из
Yep, thats a problem ;-{ which is why I had stated if you could return your system to get a system with it already. So far no 3rd party offers the custom SSD. We also tried the eBay route awhile ago and couldn't get the right part. You'll need to wait to see what happens as I'm sure someone will intro a solution.
из
It's too late, I bought it 5weeks ago. Anyway I will wait till someone find solution.. thanks for the informations..
из
Показать ещё 4 комментариев
I have 256GB Flash Storage on my iMac 5K late 2014. I'am looking forward to adding 1 - 3TB HDD to my system.
If i get necessary cable for adding HDD, like one iFixit sold: iMac Intel 27" 5K Late 2014 and Mid 2015 Hard Drive Cable
Is there still problem with 100% fan speed?
Is there any combitable HDDs to get pass this issue, or is OWC's sensor cable still the only way to get pass that problem?
Replace a broken or damaged hard drive cable for your Late 2014 or Mid 2015 iMac Intel 27" with this part to fix issues with hard drive power and SATA connection. Изображение
Товар
iMac Intel 27" 5K (Late 2014-Mid 2015) Hard Drive Cable
$19.99
Счет 2
1 Комментарий:
This cable only offers the needed SATA connection & power. You will still need the OWC in-line thermal sensor cable as well. Apple contracted with the HD vendors to build a custom HD for them. Basically its a standard drive with custom firmware so the internal thermal sensor in the drive is accessible to their SMC service within the system. Sadly Apple will not allow the HD companies to resell the HD's with this firmware. Which is why any off the shelf HD you get will require the OWC in-line sensor. This is true with either an HD or SSD SATA drive.
из
Hi
is it only me?
i purchased a cracked iMac 2015 27 inch 5k on the purpose of learn how to replace the screen and at the same time found out that you can upgrade the 3.5 hard drive to SSD so runs faster.
well not only that
i was able to install a blade apple 256GB SSD and replace the original hard drive with samsung 850 pro SSD 500GB hard drive.
everything runs great! NO need of the thermal sensor cable needed.
i have been using for 3 months no problem, using iMovie and other video softwares. fan runs normal.
i believe saw someone saying that after 2013 iMac you don't need the thermal sensor cable anymore while i was doing research before i started. so i never order one.
after replacing the hard drive. everything runs great !
but here is what i found. using the black magic app i tested the 3 possible update storage methods
1) original apple 3.5 hard drive 1T
2) upgrade 3.5 hard drive to 2.5 SSD hard drive (samsung 850 pro 500 GB)
3) install a thunderbolt enclosure with 2.5 SSD hard drive (samsung 850 pro 500 GB)
4) apple blade SSD hard drive.
here is the result
1 => 100 MB/s
2 => 350-450 MB/s
3 => 300-400 MB/s
4 => 600-700 MB/s
As you can see, there is not much difference between changing the original hard drive to SSD and using an external thunderbolt enclosure with SSD.
so after this i learned that if you are going to update just the internal hard drive. don't bother!! just get an external thunderbolt enclosure with SSD and you still keep your iMac warranty or no need to take the risk of any damage. The internal HD just keep it as extra storage.
If you are going to open the iMac. then you better install a blade SSD that is a high risk high reward.
also for people looking for the Blade SSD
i use the 2013 macbook air SSD works!!!
Oh one more thing! after doing research. only the 27 inch iMac model 2015 5k comes with the PCIe port on the logic board (this i can be sure other i don't know).
on the 21.5 inch iMac, they don't have the PCIe port. so i recommend don't bother to replace the hard drive to SSD, just install a enclosure with SSD instead. you save the trouble.
Счет 2
1 Комментарий:
The difference you see between the internal PCIe blade SSD and the external Thunderbolt drive is the drives SATA bottleneck and why the drive performance is almost the same between #2 & #3.
To over come that you could get a PCIe external drive, And then to over come the limits of the SSD write operation (which is the slower direction) you could RAID multiple drives (either SATA or PCIe) using a external Thunderbolt RAID drive (this also improves the read operation as well).
Unlike HDD's, SSD's get better performance when the flash cells are denser. So a 256 GB drive is slower than a 1 TB drive moving the same amount of data.
Here's a good reference: The Ultimate Guide to Apple’s Proprietary SSDs It will also explain the differences between the different SSD series Apple offered.
FYI: Fusion drives 21.5" iMac's do have the blade connector as well as bought systems which had a SSD (Apple installed). Only the SATA drive'd only systems don't have the parts populated on the logic board so they can't get the blade SSD.
из
I contacted Crucial customer service about thermal sensor problem. Crucial MX200 1TB SATA 6Gb/s 2.5" Seems to be 100% compatible with my mid 2015 27" retina iMac.
They answered that I don't have to use any additional hardware or software to make it work as good as my old 3.5" HDD.
So any advice? Do I trust them? If they say it's 100% compatible without thermal sensor mess. Don't want to open my iMac for nothing.
Счет 1
10 Комментариев:
Sorry, not correct! You will need the OWC sensor cable to offset the needed sensor the system requires (see above OWC link). What the rep was implying was SSD don't get hot so they don't need cooling like a HD does and that is correct! But, the issue is not the device but the system here! It's expecting the input from the now missing SATA HD so you need to replace it so the system (SMC) get the input it needs so it doesn't race the fan thinking the sensor is bad.
из
The recent OS did away with firmware/fan/temperature issues, especially after 2012. I upgraded my late - 2012 (21.5") and late 2015 - 5K (27") with SSD and the fans act just fine. However, I did have my 2010 and 2011 using the in-line thermal adapters.
Sam
из
@schen_winthrop so based on what you said do you think replacing just the conventional section of my 3Tb fusion drive with a WD 3tb drive will "just work"? (I have a late 2014 5k iMac)
из
@rossfarr - Sorry, Sam C is not correct!
SMC still requires the input of the thermal sensor. Apple didn't change anything within Sierra.
I just did a 27" 2012 and the sensor cable disconnected on me somehow in the process so I had to go back in to plug it in. The system starts off normally but after a few minutes it races the fan as the sensor input is missing.
Now the 21.5" models use a 2.5" drive and they use a different method! I'm suspecting Sam was confused between the different series.
Please do your self a big favor here and just put the OWC adapter in if you are upgrading the SATA drive. As you have a Fusion Drive you'll first need to break the drive set before you replace the HD out.
из
@danj Thanks for the clarification, I will certainly buy this adapter. I have already broken the drive set and currently have the iMac booting and running just from the SSD and i have no issue rebuilding the drive set.
With regards to the HDD, if I buy the OWC adapter can I replace it with any "off-the-shelf" HDD, such as a Western Digital? (currently installed is a Seagate)?
1 last question. Do you know if there is an iFixit version of the OWC adapter?
thanks again for your help.
из
Показать ещё 5 комментариев
Do any one find the solution for PCIe blade SSD's used in the iMac 2015? Two years gone by already :)
Счет 0
5 Комментариев:
Sadly, Apple uses a custom part and so far they are still the only suppliers. The blade drive in this series is a PCIe x4 version. While there have been reports of people using the older PCIe x2 drives. I'm not sure if its worth downgrading to a slower drive.
из
Any updates about this? Is it possible to add a 3rd party branded blade SSD?.
из
Nope nothing yet! OWC has a tease posted for something in the spring.
из
Any news on this one?
из
Update! Here's a good source for the custom Blades SSD's The Ultimate Guide to Apple’s Proprietary SSDs
из
Thanks for providing this information! After looking at your speed bench results, it seems like if your going to open up the computer, it would make a lot more sense to upgrade the Blade SSD and leave the hard drive in the computer tied together as a fusion drive, so I’m curious, what would be the downside to upgrading the Blade SSD to an Apple OEM 2TB unit. Do you think their might be restrictions to the amount of Blade SSD accessible memory or do you think the computer would recognize the 2TB and fusion drive it with the 2TB Hard drive. I’m thinking that it might be the best option as down the road if I ever wanted to expand the memory to anything more than 4TB (unlikely), I would be able to do so (fairly) easily. The part number and link below:
https://rover.ebay.com/rover/0/0/0?mpre=...
Is there any information regarding the PCIE 2.0 vs 3.0? I read on some other threads forums that the 2.0 will work but will be slower and some mixed information of the 2 lane vs 4 lane pcie options.
Счет 0
Hi Dan, I'm going to replace my HDD with an SSD.
What should I do with the Fusion Drive? Should I un-fuse or refuse with the new SSD?
Счет 0
3 Комментариев:
You'll need to break the fusion drive set. Keep in mind you can't use the two SSD's in a Fusion Drive set.
Here's how: How to split up a Fusion Drive
Frankly, I would return the SSD and get a better PCIe blade drive it will over much better performance and leave the HDD alone. Review this: The Ultimate Guide to Apple’s Proprietary SSDs and this IFIXIT guide: Замена SSD-накопителя формата blade в iMac Intel 27" Retina 5K
из
I cannot find any pcie blade spare parts,what’s the exact name of those drives?
So I can’t use the two ssds as a fusion drive,is that right?
Should I made a backup after unfusing the original drive or could I make the backup of the old fusion drive,then install the new drive,unfuse it and restore the backup on the new drive?
Thanks for any suggestion
из
Go to the guide I linked to the Gan 5 section you want a SSPOLARIS NVMe/PCIe 3.0 x4 drive 512GB or 1TB
из
Sorry, I know this thread is very old and inactive, but a lot of the original thread and its answers are very incorrect.
This should be the most definitive guide to if and/or how a model of 27-inch, Late 2015 iMac can have its internal storage (hard drive, SSD, both) upgraded.
The 27-inch, Late 2015 iMac (iMac17,1) retailed with three possible options for storage:  #1 HDD only, #2 HDD+SSD (Fusion Drive), #3 SSD only.  Apparently Apple used two different types of logic boards.... configs with storage option #1 shipped with a logic board that had SATA connections but no nVME slot, and configs with storage options #2 or #3 shipped with a logic board that had both SATA connections and an nVME slot on the back of the board (where the blade SSD plugs in).
This means if you bought or otherwise acquired a 27-inch, Late 2015 iMac (iMac17,1), the storage option of the original retail configuration will determine your upgrade options.  Here is a breakdown:
- #1: If your iMac17,1 originally contained only a hard drive (spinning disc) only, offered in 1TB or 3TB capacity, your board does not include an nVME slot, only an onboard SATA controller.
Your only upgrade option is to replace the internal 3.5-inch SATA HDD with a SSD that has a traditional SATA II/III (6Gbps) connector.  This can be achieved with regular size desktop/laptop SSDs and a mounting bracket adapter or an adapter that allows you to install an nVME blade SSD and connect to a SATA interface.
You will also need to add a HDD thermal sensor cable (the original drive has one built-in) or run a program like Macs Fan Control to keep the system’s fans from thinking the SSD is overheating and running the fans at full speed.
- #2: If your iMac17,1 originally contained a Fusion Drive (this was a combination of an SSD and a mechanical HDD, macOS would display the combination as a single volume to the user and in the background automatically move frequently accessed or important files from the HDD to the SSD to speed up performance), you have the most upgrade options available to you. Your board includes an onboard SATA controller (the HDD is connected to this) and an nVME slot on the reverse side (the blade SSD is connected to this). You have the option to upgrade the blade SSD and the internal HDD.
  • Models with a 1TB Fusion Drive have a 24GB blade SSD and a 1TB 7200-RPM 3.5-inch SATA drive installed.
  • Models with a 2TB Fusion Drive have a 128GB blade SSD and a 2TB 7200-RPM 3.5-inch SATA drive installed.
  • Models that were custom built-to-order with a 3TB Fusion Drive have a 128GB blade SSD and a 3TB 7200-RPM 3.5-inch SATA drive installed.
The blade SSD uses an Apple proprietary port that was used in several of their products from that time period but was not found on computers made by any other manufacturer.  This means the available parts you can source are limited to either used or replacement drives from another Apple machine or a third-party SSD made specifically for these Apple models (which can be more expensive than a standard blade SSD and definitely than a regular SATA SSD).  The OWC Aura Pro X2 SSD will fit.  OWC’s website lists it as not compatible with the iMac17,1 because technically it is not compatible with EVERY iMac17,1, because as this document explains, not every iMac17,1 has an nVME slot on the board.
You could also replace the internal 3.5-inch SATA HDD with the options listed above in #1. Remember, if you do this, you will need to install a thermal sensor cable or run software to override the system fans.
Your options are to replace the blade SSD and keep the internal HDD, keep the original blade SSD and replace the internal HDD with a SSD, or upgrade both. You could keep the two drives as two separate volumes or re-create a Fusion Drive(the capacity of the Fusion Drive would only be the size of the largest drive in the pair, not the total capacity of both drives combined).
- #3: If your iMac17,1 original contained an SSD, board includes an nVME slot on the reverse side (the blade SSD is connected to this).  The board also has a SATA controller, but because no SATA devices are installed (there is no HDD), no SATA data or power cables exist inside the machine to power an additional device. Obviously iMac was not designed for users to be able to expand the internal components of the machine.  While it is possible to install a second drive to connect to the onboard SATA controller, doing so would be extremely difficult. Multiple adapters would be needed to physically mount the drive inside the machine, tap in to the machine’s internal power supply, and run a SATA cable from the board to the drive’s location.  You would also need to install a thermal sensor cable or run software to override the system fans, as the SATA controller would detect a new device that was not reporting back a stable temperature.
The only practical upgrade option is to replace the blade SSD as listed above in #2. The OWC Aura Pro X2 SSD will fit.  OWC’s website lists it as not compatible with the iMac17,1 because technically it is not compatible with EVERY iMac17,1, because as this document explains, not every iMac17,1 has an nVME slot on the board.
Notes: If you are going to continue to use a mechanical HDD in your iMac, for best overall performance I strongly recommend configuring it as a separate volume, not part of a Fusion Drive, and format it as Mac OS Extended (HFS+), Journaled  (case-sensitive or not is user’s choice) or even ExFAT/NTFS if possible.
The new APFS file system is really designed for SSDs and performs terribly over time (in almost no time at all, actually) on hard drives with spinning discs.  This is why a machine with a Fusion Drive (which is required to be formatted as APFS, because the tech that makes Fusion Drive possible is part of APFS) still runs terribly with later versions of macOS installed.
If you are going to keep a mechanical hard drive as part of a Fusion Drive setup, I recommend sticking with the last officially supported version of macOS for your machine (which in all likelihood is macOS Monterey).  Newer and newer versions of macOS do more and more things in the background involving the file system (and they’re designed with SSDs in mind) and a mechanical drive is going to only struggle more and more to keep up.
Счет 0
Добавьте свой ответ
Om3r буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 21
За последние 30 дней: 56
За все время: 56,869
