Модель A1419 / EMC 2806 / конец 2014 г. или середина 2015 г. Процессор Core i5 3,3 или 3,5 ГГц или Core i7 4,0 ГГц (ID iMac15,1); EMC 2834 конец 2015 г. / процессор Core i5 3,3 или 3,5 ГГц или Core i7 4,0 ГГц (iMac17,1). Все модели оснащены дисплеем Retina 5K.
Glass Over Screen Broken
is it possible to replace protection glass over the screen ?
thanks for answer
Это хороший вопрос?
Счет 12
8 Комментариев
Please give us the last four figures of your serial number located on the bottom of your stand.
из Поделиться
serial #C02NG8ULFY11
ENC # 2806
из Поделиться
Apple iMac "Core i5" 3.5 27-Inch (Retina 5K, 2014) Specs
Identifiers: Late 2014 - MF886LL/A - iMac15,1 - A1419 - 2806
из Поделиться
Many thanks for your answer
One Ring to rule them all....
when reality reaches fiction
из Поделиться
Hi all!
I'm having difficulty determining what replacement glass I would need ... last four of serial is ...GG77 ... it's an early-2015 iMac 21.5" with broken screen glass. Works fine, is actually usable despite the crack across the screen. I don't think it's a Retina display. (I'm considering purchasing the iMac, but a lot depends on being able to replace the glass.)
из Поделиться
Показать ещё 3 комментариев
Добавить комментарий
6 Ответов
Выбранное решение
Apple in its infinite wisdom and cost cutting measures has now fused the glass to the display. So it only comes as a complete unit. Here's how it's replaced: Замена дисплея iMac Intel 27" Retina 5K
Apple Part #661-00200
Reports have been posted of some that have separated the glass but none repaired successfully.
Most units available in the USA cost around $500. A China seller on eBay has it for $310 + $65 shipping. Warning, check the ratings on these sellers.
Был ли этот ответ полезен?
Счет 4
1 Комментарий:
Are you sure about that part number? When I search it I find screens for the older, non-Retina 27" iMac.
из Поделиться
For small cracks (as long as there’s no missing piece of glass), I used windshield repair kit for cars, and it made the crack almost invisible. Costs about 10 bucks.
Счет 3
4 Комментариев:
And it worked for you?
из Поделиться
The crack is still kinda visible, but only from certain angle, and only when I'm looking up close.
из Поделиться
Wow, that's clever! I'll try it on mine.
из Поделиться
I'm really curious about the performance of the glass repair liquid. Is there still a chance to upload a photo? I have a chance to get a cracked screen for a very cheap price of 100 usd. Is it worth it ?
из Поделиться
Buying a functional iMac 5K with broken glass right now for a cheap price.
Wondering if anybody has found a glass part anywhere ?
I have a 2011 27in laying around the house, has anybody tried using that one ? Maybe by cutting off the metal parts at the bottom, it could fit ?
Thanks for your help.
Счет 1
It can be done, I have done it, I can’t find the actual glass anywhere for purchase, heat and air suction vacuum is the answer.
Счет 0
4 Комментариев:
Are you using it 'commando' or found glass part somewhere?
из Поделиться
Where can the glass be ordered from ?
из Поделиться
Hey, can you maybe outline your actions, in order to replicate that procedure? Thinking about doing the same. Did you just heated up the glass with a heat blower and peeled if off from the screen? Were there any remaining glue components on the display? Or was it something more sophisticated?
из Поделиться
Please let us know more, I have a 27inch 5k 2017 imac i need to replace the glass on and dont feel like paying $600 for it
из Поделиться
Does anyone know if the dimensions of the a1312 glass panel and the the a1419 panel are the same?
Счет 0
Could you try fitting the 2011 glass to it and letting us know how the dimensions compare with removing the metal bottom pieces ?
Счет 0
Добавьте свой ответ
Alain Buffello буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 9
За последние 30 дней: 68
За все время: 37,815
