Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797вопросов Показать все
What dose this mean
my i pod will not turn on it shows a piture of another i pod frowning and tells me to contact apple support
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Выбранное решение
Dead or loose hard drive. Could also be corrupted firmware.
Listen to the drive. If you hear it click, the drive is bad. If it isn't clicking, try and restore the iPod in Disk Mode. To do this, you reset it by pressing the center and Menu buttons in, and then pressing the center and Play/Pause buttons in. This will put it into Disk Mode to restore it. If this doesn't help, look at the drive and cable possibility again. Replace the drive, then the cable. The cable isn't the fault, in most cases. These use a platter drive, and are bumped around on a regular basis. It's usually the hard drive.
iPod 5th Generation (Video) Hard Drive Replacement
iPod 5th Generation (Video) Hard Drive Cable Replacement
iPod 5th Generation (Video) Hard Drive Изображение
Инструкция
Сложность:
Модерировать
30 - 50 minutes
iPod 5th Generation (Video) Hard Drive Cable Изображение
Инструкция
Сложность:
Модерировать
20 minutes - 1 hour
Был ли этот ответ полезен?
Оценка 1
Hi
1. first Try to Restore The ipod with itunes in Disk Mode
2. Get a HDD Flex cable and change it (sometimes this flex is damaged)
3. HDD is Dead try with another one its important the same capacity
Оценка 0
Добавьте свой ответ
kellydarcy20 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 806
