Camera not turning on.
I got this camera for my wife. She's been using it without any problem. But after she put it away for a while, the camera would not turn on even with new batteries installed. She probably did not use the camera for 3 months or longer with the batteries in it. Did the batteries ruin it?
Это хороший вопрос?
4 Комментариев
Thank you all for your suggestions, but the camera still does not turn on because I don't think it's the batteries. There was no corrosion at all. It might be a short circuit in which case I have no way of fixing it except to take it apart. Even if I did that, I would not know what to look for.
из NINO Sylmar Поделиться
Team - believe the common issue that many customers experience with this model Kodak camera is that new batteries don’t resolve the issue and there is no obvious corrosion present to clean up, so please advise what else the problem can be for the majority who don’t have a leaky old battery issue as the reason the camera (in good condition) won’t power up with new batteries. TY.
из Lori Cousins Поделиться
One of the lower battery terminal touch points has become detached. This is located through the plastic body and is not easy to reinstall.
из Jonah Поделиться
This must be a common issue with Kodak. Pathetic
из jwallace122480 Поделиться
