will it work with an intel slb6b processor?
have 2 gb of ram 159gb hdd wirh a intel dual core 1.80 processor and it hangs or stalls when using propresenter 5
Это хороший вопрос?
Это хороший вопрос?
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 28
За все время: 650
the intel processor is 2.66 ghz / 6m /1333 /05A.core 2 quad core
из Aeryn TwoFeathers
What are the model specifications on your current processor? You can check the socket of the compare those specs with those Intel® Core™2 Quad Processor Q9400S against what you have as a starting/reference point.
из Abdur Rahman
Most likely, but still possibly not. The motherboard may not support the specific processor, but it is worth a try. The socket is the same. But you may need to install a new heatsink for the new CPU. It has a higher Thermal Design Power.
Check this link if you need help installing a CPU:
Замена центрального процессора (ЦП) HP rp5700
из Nikhil Shah
