Canon EOS 60D — это 18-мегапиксельная цифровая зеркальная фотокамера (DSLR) с поворотным ЖК-экраном. Камера была выпущена в августе 2010 года; модель можно опознать по надписи «EOS 60D» на передней панели.
HELP! Error Code 70
I keep receiving an error 70 code when I try taking photos. I turned the camera off and back on, but after several photos the error showed up again. Does anyone know how to fix this?
Это хороший вопрос?
Счет 8
1 Комментарий
I get the Err 70 code to and can't do any thing else at all and after about a minute the camera shuts off. any help would be nice thanks
из Поделиться
Добавить комментарий
6 Ответов
Наиболее полезный ответ
If the automatic sensor cleaning is enabled, it causes an error 70.
That is, the automation solution is put off.
But I do not know what is the reason behind it.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
thanks seems to have solved my problem "THANK YOU"
из Поделиться
This is a memory card read/write error. First try to format the memory card. If the error continues after formatting (or the camera won't let you format the card), try a different memory card. If the error continues with a new card then you probably have an issue with the camera itself. Contact Canon for service. I hope this helps.
Счет 1
Hey everyone.
My error 70 let me shoot in auto, CA, C1, C2 and C3 on my Canon 7d mark I.
After realizing I need to somehow update my firmware and that you cant update firmware unless in settings P, Tv, Av, M or B Ifound that if I set the camera to video I could use P and update the firmware I had loaded onto a formatted memory card!
Hope this helps someone else!
Счет 1
I had this problem toobut the solution is to deactivate the autocleaning. The it shoots nornaly
Счет 0
4 Комментариев:
I have this problem too and have format the card but still writing error 70
из Поделиться
Please help me
из Поделиться
Have AUTOCLEANING set to OFF
из Поделиться
Please check image Sensor
из Поделиться
Hi, i fixed this error on my EOS 600D with Tornado EOS program. Do factory reset and problem solved.
Счет 0
1 Комментарий:
what do you mean Tornado EOS program?
из Поделиться
I faced the same issue on my 60D.
Tornado EOS programn is really awesome! I used the free version to upgrade the firmware and problem solved!
Счет 0
Добавьте свой ответ
Tyler Vaal буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 17
За последние 30 дней: 105
За все время: 27,007
