Наушники Monster DNA, выпущенные в 2012 году, номер модели — MH DNA ON WHT CA WW.
Why is one of the speakers working?
Whenever I use this device, I have found out that there is a problem with speaker because I think that the sound quality seems poor. What can I do in order to fix it?
Это хороший вопрос?
Счет 3
Добавить комментарий
2 Ответов
Наиболее полезный ответ
My daughter had the same problem. Only one speaker working.
It turned out that the connector cable (the cable with the TRRS plugs on both sides; which transmits the signals from the audio source to the headphones) had a broken wire.
I found out by checking the conductivity of the cables with an ohmmeter, probing sequentially the corresponding segments of the TRRS connectors (if you don't know what a TRRS connector is, check on Wikipedia under "phone connector (audio)").
The cable is very flexible and is coated with a very soft rubber-like plastic. It invites rolling up the cable to a tight coil, or playing with it and bending it strongly while listening to music. This is how one of the wires may have broken.
So, before you dissassemble the headphones (and possibly damage them in the process), first check the cable leading to the headphones.
Был ли этот ответ полезен?
Счет 2
In order to solve this problem, you should check to see if anything is blocking the speaker. If that is not the case, then there may be a loose internal wire or the speaker may need to be replaced.
Счет 1
Добавьте свой ответ
Mesfer буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 14
За всё время: 3,039
