Visual Land Prestige Elite 7Q is a 7" Tablet with a quad-core processor, 8GB of memory, and comes with Android 4.4 (KitKat).
Why isn't my tablet working
My tablet wont come on
Это хороший вопрос?
Счет 1
3 Комментариев
What have you tried? Charged it? New charger;new cable?
из
Can you try to describe your problem in detail? What is the situation of your tablet now?
из
My touch isn't working at all. Power and volume buttons are but no touch???? WATS wrong
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
There may be a problem with the battery or charger, check out the Troubleshooting Guide for more information.
Был ли этот ответ полезен?
Счет 1
Have you tried charging the battery? If you plug in the tablet but the battery won't charge, the battery adapter may be broken. If so, try using a different battery adapter and see if that works. If you have exhausted these options and the tablet still does not turn on, then the problem may be with the tablet itself. In that case, you could try replacing the battery in the tablet because it may have run out of juice.
Счет 1
The Reason Is Probably Because It Needs To Be Restarted.
Счет 0
Добавьте свой ответ
Tina Stone буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 24
За всё время: 364
