HP Stream 7 — это компактный многофункциональный планшет производства Hewlett-Packard, выпущенный в сентябре 2014 года.
Screen is un-responsive to touch
How should I approach getting my screen to work again? It will not reach to my finger when trying to use it.
Это хороший вопрос?
Счет 2
1 Комментарий:
screen is blue and says it needs to be hooked up for repair. Have plugged it into my laptop but with no change.
из
Добавить комментарий
2 Ответов
If the screen does not work make sure that the device is charged and also clean the screen of any debris or oils that might be inhibiting the screen from reaching to your finger. If this still does not work try to power down and/or reboot the device. If all else fails it is likely that the screen has gone bad and may need replaced. If the device has been dropped or has a cracked screen this could be a likely problem.
Был ли этот ответ полезен?
Счет 0
The screen is blue and says it needs a repair and is not hooked up to the required device. what is the required device?
Счет 0
Добавьте свой ответ
Alek Minkis буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 19
За все время: 828
