Dell Streak был выпущен 13 августа 2010 года и эксклюзивно доступен в сотовой сети AT&T в США.
Can I replace the Speaker
The speaker on this device is totally rubbish. It cracks and crackles, the speakerphone is almost unusable. Is the part easily replaceable and if so can you recommend a compatible excellent replacement?
The ear speaker is also horrible in that you cannot hear anything unless you've absolutely directly paired your ear canal and the tiny slit. Any suggestions of a solution for a louder speaker here?
Thanks, Ravi Shanghavi, Ottawa
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
Выбранное решение
I have had people tell me that "removing the cover over speaker helps with sound volume" so I gave it a try and will describe how to here. I will assume that you saw the teardown post for that is the best how to guide I've seen to date. For this mod you only need to remove the plastic bezel that covers the internal speaker.
Once cover is removed (it is held on with rather sticky tape so be careful not to crack it. I reccomend using the plastic tools shown in teardown post) locate the sticker covering the speaker
using tweezers, or whatever floats your boat, to peel off sticker.
Now simply replace the plastic bezel. I noticed a slight difference is sound, especially with directionality. I no longer have to have slit directly over my ear canal. Slightly off center works well now.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Ravi Shanghavi буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 15
За все время: 2,360
