BlackBerry Bold 9900 — это смартфон с полноценной QWERTY-клавиатурой и сенсорным экраном.
Phone wont switch on
Hello have a phone problem ,it doesn't switch on the screen is black even after I changed batteries===
Это хороший вопрос?
Счет 5
5 Комментариев:
We seem to be having the same problem, mine only flashes red when u try to put it on but yet remains blank
из Поделиться
same problem
из Поделиться
My blackberry bold 9900 won't turn on I tried a new battery and it only worked for an hour or 2,then I charged the two batteries else where it also for an hour or two . when plug in the charger the led light turns red and u only see battery charging sign that's all.
из Поделиться
Same problem
из Поделиться
Phon chargeing problam
из Поделиться
Добавить комментарий
1 ответ
Hello geraldmtshali,
  • install blackberry manager
  • Connect the phone via m.USB cable
  • Update the firmware if available otherwise you can do the repair the phone by blackberry manager
  • Fallow the instruction
Hope above steps will help you to fix your BB
Был ли этот ответ полезен?
Счет 0
4 Комментариев:
I removed my battery out of my phone, then when I put it back in again which was about 1 hour later it wouldn't turn back on, it has no LED flashing at all, I've tried plugging it into the charger and nothing happens and plugged it into the laptop that also done nothing. The laptop doesn't even realised I've plugged it in.
Can anyone help?
из Поделиться
Hello shuvo, does BB manager detects your phone ?
из Поделиться
no brother its not :(
из Поделиться
Then it should be hardware fault. simply you can check the micro USB connector either it physically damaged.
из Поделиться
Добавьте свой ответ
geraldmtshali буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 32
За все время: 6,078
