Asus ZenFone 2 (ZE551ML) — это смартфон на базе Android, выпущенный компанией ASUS в марте 2015 года.
Having problems with my display
hi, i have a problem with my zenfone the screen has some weird lines going down, what connector should i try disconnecti and reconnect to get it to work properly (the phone have been wet)
Это хороший вопрос?
Счет 6
3 Комментариев
Hi,
when reading the problem outlined above just wanted to say that I also have a problem with zenfone, similar lines appear but I have never dropped my phone into the water nor on the floor. It just hapened without any reason. I had this phone for just over few months.
Any idea what shall I do, please?
из
Hi, I have a problem with my zenfone 2...
You know when you restart it, it usually shows the starting screen where you have to put the passcode to enter the homescreen...it doesn't show up on mine...
Can any of you tell me what to do...please?
из
hi i have a problem with my zenfone 2 some times there are area in the screen that cant touch then sometimes it will go to other application even you didnt touch do you think its the screen is the problem or is it in the lcd ? if i will replace it is my phone going to be ok
thank you hoping for your answer
из
Добавить комментарий
8 Ответов
Наиболее полезный ответ
the problem is probably oxidation(rust) due to the water damage the best is to put the mother board in a ultrasonic cleaner in order to remover and stop rust from spreading
BTW the connector you are looking to is the LCD connector (since you can not put the whole lcd in liquid you will have to clean it manually whit an esd safe brush)
Был ли этот ответ полезен?
Счет 2
3 Комментариев:
Well after 3 months the problem just got back and this time all the screen would get the lines so i bougth a new screen and changed it, took me like 1/2 an hour following a tutorial on youtube and now my ZenFone is as good as new, checked for the connector rust and is just as @reparactif said, but due to the small size of the connector i went for the change, the new screen costed $23 dolars and got a new tempered glads for $7 and special tape to fix the scrren in place for another $12 in amazon after a couole of months i will share how well the new screen is doing.
из
Update... Is the 4th month with the new screen and so far still as good as new. Posting from my Zenfone.
из
I changed screen and boot new one but after 2 dayes the new is damage same flickring
из
I got the same problem, while trying to fix it changed the recently updated ZenUI Launcher with the Google Launcher to give it a try and now i only get the lines in the unlock screen and in the Asus Gallery not the Google photo gallery, i think the problem lies within the las OS update i received last week.
Счет 2
3 Комментариев:
i have the same problem since the zenUI update... It started with horizontal lines in the middle of the screen, now it's from 2/3 from the bottom, sometimes it turns white, it bugs a lot when black images, when white it goes better...
i hadn't the problem before update
My phone was never wet, i wondered if it came because my phone went warm a lot while fast charging. I hope asus will solve the problem.
I just had an OS update but it bugged. while trying to update, i had the same screen bug on boot and on update screen after rebooting.
Sorry for my bad english, i'm french, i hope it's clear enough
из
Update: after a week using Google Launcher the lines dissapeared and i had no more problems with my display so till the next update for the ZenUI i will stick to Google Launcher
из
I got the same problem with my asus zen fone. It gets horizontal lines in the middle of the screen and sometimes the lines appear 2/3 from the bottom. My phone never get wet nor dropped. And I have my phone for just few months. What should I do? Need help soon, please.....
из
Hello! Experienced flashing of lcd and rainbows on 70% below of screen while the upper 30% is normal. Just tried clearing cache of zenUI Launcher. Hope this helps
Счет 1
2 Комментариев:
this is happening in four consequence time and every time the set produced before asus care for software loading, and thereafter it is functioning but after the gaph of 02 to 03 months it happened, is there any permanent solution?
из
Allan! Out of all of the research and technological solutions I could find, this worked! Reminds me of the movie Sling Blade when nobody could figure out why the mower wasn't working..."it ain't got no gas." I never make accounts for threads but you saved me from buying a new phone, thanks!
из
Hi I have an annoying problem with my zenfone 2.. the screen is flashing on and off.. i didn't dropped my phone. it was very lag so i decided to turn it off and when i turned it on the screen keeps on flashing on and off... and i can't use it anymore.. i tried several times shutting it off and truned again but still nothing happened
Счет 0
during booting it is hanging, even though so many time switch off & on the set
Update (11/03/2016)
Update (11/03/2016)
no, ur answer is not acceptable by me, as it is happening 03-04 times with me and every time I go to asus care where they did software loading and then it is functioning.
Счет 0
This problem is being caused by some loose gap on the back of the screen, to solve this problem, you need to make sure the screen is well secured. To do so, just open the back cover and unscrew the battery cover, then stick some very thin foam over ( & around the edge of the motherboard ), make sure these are not covering the camera, volume button etc .. then screw back the cover gently. This should solve the problem!... if still not fixed fully stick some of the same thin foam under battery which isolates the battery from the screen and fixes the screen and problem should go away!
Счет 0
Hi, If it has been wet most likely that screen or board is damaged!
However the screen connection has two leads to the mainboard . On is for LCD and other is for digitizer touch glass. When you open the back cover
The LCD connector is on the far left coonector just above the battery and digitizer has a very small lead fuether up on left connected under metal cover.
You need to lift the metal cover carefully and lift thr connecor latch and the pull the small flat cable. Be carefull this can be damaged if try it hard.
Hope this help
Счет 0
hey my asus zenfone 2 is not showing the home screen or any other app it is just showing a circle clock n all back i have to turn it off when it shows tht clock kinda thing and some initial setting like camera aroplane mode seelp mode..and when i restart it then it works good for 2 to 3 hrs and then again my sreen fleshes with the same...i dont know what to do will i have to stop using it or is there any solution for it...if yes...plz some body tell me...
Счет 0
Добавьте свой ответ
JanOve буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 20
За всё время: 25,805
