Brother MFC-3240C — это цветной струйный принтер «5-в-1».
help me clear error 46
i am having a problem and my all in one is saying error 46 help me to repair
Это хороший вопрос?
Счет 4
Добавить комментарий
1 ответ
Выбранное решение
Machine Error 46, Purged Ink Box Full
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An initial purge, for example, advances the purge counter by 187 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unusable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: unplug the unit, hold down the Menu/Set key, re-insert the power plug while holding down the Menu/Set key. The internal Machine Error Code will be displayed. Unplug and re-plug the unit again before continuing to the steps below.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter:
  1. Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
  2. FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
  3. Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the up arrow key four times to enter the maintenance mode).
    1. Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
    2. Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
    3. Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
  4. Press the Stop/Exit key to return to the initial stage of the maintenance mode.
  5. Press the 9 key twice to return to the standby state
Был ли этот ответ полезен?
Счет 6
6 Комментариев:
This answer was incorrect for Brother MFC-3240c.
из Поделиться
Then post your own solution if you're able to fix it!
из Поделиться
Any clues as to how to dismantle the printer?
Don Minow
dminow@comcast.net
из Поделиться
Printer is a Brother 490CW using LC65 black cartridge/LC60 color.
из Поделиться
All you have to do before purging counter, you clean all silicon hose for dispense ink absorber and clean the absorber respectively.
из Поделиться
Показать ещё 1 комментарий
Добавьте свой ответ
xmansean буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 13
За последние 30 дней: 42
За все время: 16,468
