loud knocking on spin cycle
Hello. When our samsung front load washer gets to the spin cycle it sounds like horses are galloping through the laundry room. It is under warranty. They replaced shocks....just as bad or maybe even worse. If you are in the room it's so loud you can not hear a person talk beside you. I read a few of the other questions of similar nature on here but didn't see on where shocks had already been replaced and checked that not clothing or foreign objects in machine. I video recorded the sound when I turn drum by hand. The bang happens when you move the drum so simple to reproduce the noise. The tech seemed stumped so I thought I'd ask professionals online. Thank you for any ideas.
Это хороший вопрос?
10 Комментариев
My samsung washing machine 16.okg .once it come to spin d drum inside make a lot of noise like dancing...can someone tell me what to do pls
из Olashile mike Поделиться
It’s the spider arm that’s attached to the bottom of the tub. Major defect that’s happened to so many people.
из Matt Bowen Поделиться
Samsung washers and warranty are lousy. My drum is out of round! The machine pounds like crazy. Cost $80 for a service tech to come out and tell me it cannot be repaired because the drum, shaft, motor are all integrated. I'm very upset and will avoid Samsung in the future. Drum ought to carry industry standard 10 year warranty. Not Samsung.
из chris Поделиться
I also had this same problem. I replaced the spider arm, both bearings and seals and all four shocks. It still does the same thing, on medium spins it wobbles so bad it bangs the side of the cabinet. I replaced the shocks because I noticed about a 1/2 inch free travel with no resistance on them. Upon getting the new ones I noticed the same thing. So they must produce them with that play. Machine is dead level some loads it’s not as bad but never did it before.
из David mills Поделиться
My door literally bangs back and forth during spin cycle. Can anyone tell me how to tighten the door so it stays sealed. If I press on it it stops it. It is literally the door not being tight enough. Please help.
из canjan will Поделиться
Показать ещё 5 комментариев
