Шестое поколение iPhone компании Apple, представленное 12 сентября 2012 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в Черном или Белом цвете.
2522вопросов Показать все
Front facing camera not work
the phone is droped badly when i assembled whole logic board in other housing with new lcd and flex cables everithing is working except the front facing camera on image is the missing part but everithing else is on place i think. please tell me what to do... thanks
Это хороший вопрос?
Оценка 0
2 Комментариев
I never had this instance before but I think you should get your phone fixed first and then go to the store where you got your phone from. Ask them how to fix it.
из
When you reassembled the phone to test it you didn't get anything over the camera by accident did you I have had occasion to get tape or glue on the lens not realizing it was covered It doesn't take much
из
Добавить комментарий
4 Ответов
Выбранное решение
i fix the board ,and now the camera is working.... there are a missing component above the screw ring, the third component from right in the first row just above the ring that i miss.
thank you all for yours time, thanks alot :D
Был ли этот ответ полезен?
Оценка 0
Наиболее полезный ответ
Wait I'm confused. Why can't you just put a new front camera assembly on there?
Оценка 1
4 Комментариев:
i also do a microsoldering and tht stuff but i can find a problem, i put a few new cables but nothing ....
из
do you have any idea what should i do?
из
i think its a hardware error
из
I'm not sure which part your missing
из
That board looks fine in that section. Rule out bad part. Rule out software--front and rear cams are dependent on each other. After that, head to schematics--search for Cam 0 and cam 1 --follow lines, measure voltages in and voltages out. Look for missing damaged components, that's all you can do
Оценка 1
Hi .
I had similar problem with my iPhone 3 since last year .
It resolved after I updated my iPhone 4 via iTunes .
It might work orbit could be a hardware issue .
Regards ,
Kksilvery .
Оценка 0
Добавьте свой ответ
Vladan Vojinovic будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 2,960
