Xperia Z1 Compact — это премиальный камерофон от Sony. Он похож на модель Xperia Z1, но меньше и дешевле. Его ключевая особенность — 20,7-мегапиксельная матрица. На момент выпуска устройство было доступно в белом, черном, розовом и лаймовом цветах. Данное устройство можно идентифицировать по номеру модели (D5503).
Screen not working after replacement
Hello I have Xperia Z1 Compact with a broken screen. I have ordered a replacement screen from ebay. When I connect the screen to the phone and turn it on, nothing happens. I know that the phone works because I hear boot up sound. Also when I press unlock button and then volume up/down keys I can hear the volume change sound. If we assume that the replacement screen is working, what could be wrong with the phone? Is there anything I could do to fix it?
Это хороший вопрос?
Счет 1
1 Комментарий
I have a similar problem, i tested the new screen and was satisfactory, however after installing it with the gasket it failed to fire up
из Поделиться
Добавить комментарий
1 ответ
Наиболее полезный ответ
The LCD ribbon cable could have been damaged during installation. Make sure the lcd connector is connected prperly. You might have a defective part, eBay parts are not always the best choice....
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Thanks for the answer. Unless the ribbon was already damaged I doubt I damaged it. Connector is easy to access and I was gentle. I was wondering what chances are there that there is something wrong with the phone itself. For example that metal panel below the display (is that heatsink?) seems a bit detached now. Could a connector itself be a bit detached from the board?
из Поделиться
Добавьте свой ответ
Ivan Savu буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 13
За все время: 1,367
