ZTE Boost MAX N9520 оснащен 5,7-дюймовым HD IPS-дисплеем с поддержкой 4G LTE и работает на базе Android 4.1.
Why won't my external speaker work?
External speaker won't work. Internal work's fine. I can hear music with ear buds, I can hear phone conversation as long as it's not on speaker. My ringer doesn't work as well. Hasn't had any water damage. I did have a cracked screen but it was just replaced profesprofessionally.
Это хороший вопрос?
Счет 0
2 Комментариев
Hi,
How long since it was repaired? Was the ringer function working when you got it back from repair? Does the repairer give a warranty on his work? If it has not worked since his repair (how often do you use the loudspeaker function) it seems very coincidental, contact the repairer and ask. The ringer function (not vibrate) uses the loudspeaker so if it is loose or faulty that is probably why both don't work
из Поделиться
Why no one can hear me but I contacted hear them
из Поделиться
Добавить комментарий
1 ответ
Выбранное решение
Hi Faith Randall,
Have you checked the volume setting for the loudspeaker?
Go to :
Menu > Settings > Sound > tap Volumes > slide volume control for Loudspeaker to desired volume.
Был ли этот ответ полезен?
Счет 3
1 Комментарий:
Yes I did check the volume
из Поделиться
Добавьте свой ответ
mark буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За все время: 1,575
