Dell Precision M4600 — 15,6-дюймовый ноутбук, входящий в линейку мобильных рабочих станций Dell с высокой производительностью, был выпущен компанией Dell в период с 2011 по 2013 год.
Screen Flickering when start from Cold
My Laptop Screen flickers with fuzzy pixels when it start from cold and still flickering until it warm up then i should close the lid and open it again to disappear and back to normal state.i attached external monitor to check if this from graphics card but external monitor worked fine without any problem.i want to know if this problem from the screen itself or problem with the motherboard?
this video show how it`s flickering.it`s not my laptop but just for clairfying the problem.
https://www.youtube.com/watch?v=ctHn8P-2...
Thanks in Advance.
Это хороший вопрос?
Счет 1
Добавить комментарий
3 Ответов
Выбранное решение
hi ,
I disabled optimus nvidia option from bios and this solved my problem.thanks for your help :)
Был ли этот ответ полезен?
Счет 0
Наиболее полезный ответ
mahmoud eldeep since it displays properly on an external monitor, I'd exclude the motherboard/GPU. It is easily possible that you are having issues with the LCD. I'd start there.
Счет 2
9 Комментариев:
Thanks for your fast reply. but is there any explanation for this phenom? is cold can effect on the screen and make it flickering like this?
из Поделиться
Yes it can. coils,caps and resistor as well as transformers can have cold solder joints that may close during warm up.
из Поделиться
I`ll replace my screen and feed you back with the results. Thanks Man
из Поделиться
I have another Dell Latitude E5520 with Screen of 15.6” HD (1366x768) Anti-Glare LED. I exchanged the two LCD and my screen works fine till now on latitude without any flickering from startup and latitude screen works fine too on my laptop without flickering at startup too till now.my screen is 15.6" 1920x1080 HD Ultra Sharp Anti-Glare LED.what may cause this problem??!
из Поделиться
the problem not from the monitor as i replaced it with another low resolution one (1366*768) and it did not show up the problem.i think it`s something related to power input from graphics card to the monitor as FHD monitor consumes alot of power than the HD monitors.but i still can`t determine which part i should replace.
из Поделиться
Показать ещё 4 комментариев
https://okadtech.com/dell-laptop-screen-...
Hope this will help you
Счет 0
Добавьте свой ответ
mahmoud eldeep буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 6
За последние 30 дней: 43
За все время: 9,367
