15,6-дюймовый дисплей. Идентифицируется по номеру модели: NP470R5E-K02UB. Устройство было выпущено в августе 2013 года.
Do not attempt keyboard replacement.
Hey everyone,
This isn't so much a question as a word of advise. Do NOT attempt to replace the keyboard on this device without purchasing a new palmrest/top case as well. The keyboard is held in by what looks like plastic rivets, and is VERY difficult to replace on your own. I've attempted a keyboard-only repair a few times, and I won't let it happen again. It takes much too long to tear off all the plastic rivets and glue the new keyboard down, and you end up with a less than satisfactory repair every time.
Это хороший вопрос?
Счет 4
1 Комментарий
Where did you order the palmrest/top case that you recommended. If you could provide the part number, that might be helpful if a future repair is required by someone who reviews the post.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
I had the same experience. Had to completely disassemble the laptop to get to the keyboard, then cut off the plastic rivets with a box cutter to remove it. Well, OK, my student worker did. I supervised. It's nice to have minions. It did turn out well but took a few hours.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
hi brianstrech,
how did you guys glue the keyboard back?
из
Добавьте свой ответ
Max Rysdon буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 11
За последние 30 дней: 30
За все время: 1,976
