Samsung NX30 — это беззеркальная камера со сменным объективом. Она поддерживает видео высокой четкости (HD) и была выпущена 18 февраля 2014 года.
The flash isn't working!
Alright, I bought this camera about 2 weeks ago and have everything still, used it right out of the box until yesterday, when the flash wouldn't work anymore. I've done all I can without breaking the thing, the button doesn't really work so I kinda have to force it open (which I don't want to do because it might break), and then once I do get it open the flash isn't working. Is it possible I need to take it apart and replace the bulb? If so, I'm not really comfortable with that, but is it possible this could be a software issue?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
Hello William, is the flash bulb slightly dislodged? That may be why the flash head does not open up easily when you press the flash button. You can use a screwdriver to remove the screws holding in the bulb and then adjust the bulb and screw it back in properly. Once the bulb is in properly, the flash might start working again, otherwise you may have a dead bulb.
If the flash bulb is dead, this is an easy fix - you can just follow the guide right here: Замена вспышки Samsung NX30.
All you have to do is get a spare bulb and switch the dead bulb out by unscrewing a couple screws.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
For further help, here is a link to the troubleshooting page for the specific issue: Samsung NX30 Troubleshooting
из
Добавьте свой ответ
William буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 25
За всё время: 1,253
