SIM 1 no signal
hello, i have the asus zenfone 2 and today i have problems with slot1 sim card, sim car is insert but is not singal service, when i put de sim in the slot 2 that work god. please i need help.
Это хороший вопрос?
Это хороший вопрос?
The root of the trouble is mostly because of the loose Sim 1 slot.
What I did with mine was placing a folded paper between the two sims in order to push each other firmly to their slots.
Был ли этот ответ полезен?
Actually the sim slots are all good, problem is with the buggy $@$*!& ASUS stock android os. I replaced my stock os with lineage os, and it is all fixed, no network problems, and the performance also improved. ROOT it. TRUST ME
I have ZenFone 2. When I traveled to Taiwan, I used the sim card from TaiwanStar, it worked fine. But when I returned to USA, I replaced it by the original sim card, and it cannot be detected. I have experimented by swapping the sim cards in two slots, and trying one sim card in only one slot, ect. And it works now. My impression is something is sticky inside that I do not understand. But if you swap the sim card a few of times, it should work.
I have some problem, I already do factory reset, downgrade firmware coz I think use to be my SIM 1 is normally in older firmware, but it still doesn't work, still not signal :'( I'm sorry for my bad English, and I can't give u solution, but I hope u not do what I've done, coz still the same.
I 've some information that u can try to use original micro SIM ( i mean not use cut SIM manually). I'm not try yet.
Me too have the same problem, quess this not simcard slot but hardware problems
Hello,
I think its the antenna cable, since this is broken i have no signal on sim card 1 slot.
http://www.aliexpress.com/item/For-ASUS-...
I will buy this.
I agree with this, antena problem.
I already make jumper from antena but sometime its also no networks again..
Solution : change new device broth!!!
I have the same issue, I ordered the Asus Zenfone 2 SIM Card Reader Holder Connector Slot Flex Cable Replacement and will replace it as soon as I receive it by mail. Ordered it through ebay for 10$CAN
It worked! I received the item and it wasn't working, the seller on ebay sent me another one and now the phone WORKS just as it did before. Though it was a little pain to replace it ended up working.
It may be due to loose contact. Try the following:
Remove the sims. On the back of each of the sims place two layers of thin cellotape or packaging tapes.Trim the edges. Now insert the sims. Also place a thin hard strip of plastic ( even a match stick piece) in between two sims so that they do not slide out. Over this, again put a piece of cellotape
See now your sims will work, unless of course the phone other has major issues.
Dr Sundara
Let me tell you my journey how I got slot 1 unavailable intermittently:
Most latest phones do not support dual SIM although they have two SIM port. Contact to the customer service center.
Hi @davidmiller35 ,
Just curious as to why a manufacturer would go to all the trouble of designing and manufacturing a phone to have two SIM ports and then not have them both work.
Do you know of any phones where this is the case?
I'm not talking about dual SIM phones that have problems just ones where you say that dual ports are installed but only one actually work.
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 23
За всё время: 69,387
11 Комментариев
both of my sim cards are not being detected please help
из Fatou Ndiaye
I have zenfone 6 with similar problem, sim 2 not detected. Have tried swapping the SIM cards around, and they both work fine in slot 1
из Kim Cw
Ich habe ein Zenfone 2.Die Sim Karte habe ich vom Samsung überneommen.
Sie hat alle Daten übernommen, steigt aber nach kurzer Zeit regelmäßig aus und ich muss immer einen Neustart machen! Dann funktioniert die Karte wieder? Was kann ich da machen?
из stehling.rosel
Bot sim 1 and sim 2 are no signal please help.
из lloyd nava
The sim card cable has become disconnected from the main board. It happens a LOT on the ZenFone 2. Check out the Tear Down screen shots. You will see exactly what I am talking about.
из Robert McTear
Показать ещё 6 комментариев
