Смартфон Alcatel One Touch Idol 3 оснащен 5,5-дюймовым дисплеем с разрешением 1080 x 1920 и работает на базе процессора с частотой 1,5 ГГц. Выпущен в июне 2015 года. Модели: 6045Y, 6045K, 6045O, 6045I.
My Powerbutton don't work anymore?!
My Phone was always covered by a Flipcase, yesterday i took it out cause the Powerbutton did not react.
But now it dont work anymore. At first it worked after 10 times pushing, but now i have to wait for any message, that the display come out oft "sleep" mode...
what can i do ?? i dont know if i can fix it alone :(
i dont want to loose this phone, its really New... Please help me.
Это хороший вопрос?
Счет 2
Добавить комментарий
2 Ответов
the power button on the idol 3 can be finicky as they are prone to failing. they ARE soldered to the circuit board so I would advise finding a local electronics repair shop or good friend with minimal soldering experience- seeing as the actual replacement is as simple a solder job as one could imagine . the component replacement, itself, is about $8.00 online.
http://www.ebay.com/itm/Alcatel-One-Touc...
Был ли этот ответ полезен?
Счет 0
I was having the same issue for almost a week now. My phone is visibly in great condition (screen in tack, no cracks or scratches, etc.), but the power button just gave out on me. The only time I was able to use it was if I plugged it into the battery.
Finally, i decided to download an app by searching "Power Button to Volume Button," and voilà it works. I now use my up or down volume to turn my phone on! I hope this helps you, too.
Счет 0
Добавьте свой ответ
Christine буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 25
За все время: 1,484
