Обновленная в марте 2015 года модель 13-дюймового MacBook Air от Apple оснащена процессорами Intel Core i5 и i7 пятого поколения, что обеспечивает небольшое повышение производительности и времени автономной работы.
Location of power pads
Macbook air with liquid damage, did a board cleaning and device powered back on. Now a couple month later it doesn't power up.
While trying to reset smc I notice there are no change to the charger indicator light. I suspect the power button has failed. I'm looking to jumpstart the macbook air to validate that, and if so, change the keyboard assembly.
I know Macboks usually have a couple power pads that can be bridged to power it up.
Does anyone know where they are?
thanks
Это хороший вопрос?
Счет 3
Добавить комментарий
1 ответ
Выбранное решение
Emmanuel Marti check the attached image for location.
Был ли этот ответ полезен?
Счет 10
7 Комментариев:
Hi!
I have the same problem. I have now located the "debug power button". But does not work to press on them. How do you do it? And why did you put a red circle around the black thing?
из
knutegil11 the red circle is from another guide where this image comes from. disregard it. you will need a flat head screwdriver or a paperclip to "bridge" the two contacts in the blue circle. If that does not work, then you are having plenty of other issues with your board.
из
Ok, then I guess my Mac is broken for sure... Thank you for answering :)
из
Before you get rid of it, track another ultrasonic cleaning with some Branson ec.
из
@gigabit87898 why? knutegil11 did not mention anything about water damage or any other damage.
из
Показать ещё 2 комментариев
Добавьте свой ответ
Emmanuel Marti буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 11
За последние 30 дней: 65
За всё время: 25,659
