Выпущен в 1993 году, идентифицируется по надписи TI-82 в верхнем правом углу экрана.
Screen fading. What do I do?
There is a line down the right side that cuts the answer off. How can I fix it?
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Oh no! That sounds bad. Here, I don't have a Texas instrument calculator, but I can give you some tips! :)
1: Please check the volts on both the battery and the display, if they look fine, go to step 2.
2: Look for any damaged or misplaced cables. Sometimes they can cause a problem, oh and look for loose screws too.
3: If it still dosn't work, it might be a circuit board problem. There's not much you could do with that. We could buy another one on ebay, here's one I found. TEXAS INSTRUMENTS TI-82 PERFECTLY WORKING SCIENTIFIC CALCULATOR
Thank you for your patience! :D
Был ли этот ответ полезен?
Счет 0
@joilet This is a 8 year old question but somehow it popped up on the list. I am certain by now you either have it fixed or have a new calculator. Anyhow, this "line down the right side" and the fact that it is fading points to a bad display or corroded display adapter. Use something like this video to resolder the ribbon cable. If that does not work you may have to replace the screen. There are different versions for the screen, so you will have to get the LCD number from the current display since it will be specific to your calculator.
Счет 0
Добавьте свой ответ
Eden Brock буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 10
За всё время: 589
