BLU TANK II T193 Аккумулятор-монстр, 30 дней в режиме ожидания Разработано BLU в Майами | Собрано в Китае www.bluproducts.com
Why is the screen not working?
why is the screen is not working when the device is on ?
there are many reasons that the screen would not work when the device is on. but, before let us list some causes that might lead to this effect. The first one, it could be due to the device fall down on the flower. Second, there might some water came on the phone.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
if your phone fall down and you notice the screen is not working or there is a deletion on it you would have two cases.
One, you first have to know that there are two type of screen in any device outer and inner screen. Therefore, if there is a scratch on the screen that means it is the outer screen so consider replacing it. Next, if there is no scratch but the screen is just not working then there is a big chance that the inner screen is damaged. Hence, no need for replacement so just go for new phone because replacing the inner screen would cost a lot near to the price of a new device so buying a new one would be the better idea.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
khalid jaafar буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 363
