Display show P1 message?
Duracraft DD-TEC10NE, after pressing power button display show PI ( P1) message that I can not clear to make it work. Any ideas ?
Это хороший вопрос?
Счет 9
4 Комментариев
I have the same problem. I think the humidity sensor is broken. Now the question is: what model of the humidity sensor is used here?
из Поделиться
Time to tear it apart and find out. Take lots of picture and make a guide for the rest of us.
из Поделиться
I replaced the humidity sensor and checked the black sensor that sits one the same module. Both are working. Also the temp sensor was fine, still I get the P1 error…
из Поделиться
How should I disconnect those 4 cables from the board?
из Поделиться
Добавить комментарий
11 Ответов
Выбранное решение
dulebu, the P1 error message means that the temperature in the room is too low. The temperature should be no less than 18 degrees celsius or the humidity in the room should be below 30%..
Был ли этот ответ полезен?
Счет 5
3 Комментариев:
Thanks, but room temperature is about 20 celsius and humidity about 70%.
Is there possibility that humidity sensor is broken ?
из Поделиться
Yes that is very much a possibility. A failed hygrostat appears on the forums about the P1 error a lot.
из Поделиться
Hello can I get a link for the sensor because I have the same problem?
из Поделиться
Наиболее полезный ответ
Duracraft DD-TEC10NE: I take some pictures.
Control Plate:
http://www.fotos-hochladen.net/uploads/w...
Hydro-Stat-Modul:
Temperature Sensor:
To open that device you need a normal cross screwdriver and for one srew you need a torx srewdriver with torx 10.
Update (28.01.2017)
To repair the p1 error you have to replace the Hydro-Stat-Modul.
I do that and it works fine for me. Also you could only replace the hydro sensor on the old plate.
If you only want to replace the hydro sensor it would costs only 8,93€ + shipping costs
Why have I do that because my warranty had come to an end for one year so - I don't want to repair his device from the producer for a lot of money etc. and because it's fun to repair something yourself.
Счет 6
19 Комментариев:
Sry it was not torx 15 it's was torx 10
из Поделиться
Hi,
Can you tell which partnumber the hygrosensor is you used?
BTW:
The little black component on the Hydro-Stat module is a temperature sensor used for the hygro measurement (combination of temperature and humidity to measure relative humidity)
The Temperature sensor you mention is the sensor that protects the cooling system from freezing and overheating.
из Поделиться
Partnumber (EAN) 4016138323856 Hygrosensor ...range from 0 C°-60 C° under 0 C° it will show 20%. I hope I could help you.
из Поделиться
Thanks a lot, that helped. I did already try some other sensors like the HR202L without success. Will order a EFS10 as you suggested to try that.
из Поделиться
Where i buy the sensor Hydro-Stat-Modul?
из Поделиться
Показать ещё 14 комментариев
Thermistor is 10kohm
Счет 4
1 Комментарий:
Hi can you tell technical Data or the Name of the spare part
из Поделиться
The lead of the Thermistor on the Hydro-Stat-Modul of my Duracraft DD-TEC10NE has been corroded to the point that it didn’t made contact anymore. Please see the following picture:
I cut away the corroded part of the Thermistor leads and put it back in. Now it is fixed and seems to be working just fine again.
Счет 2
4 Комментариев:
Welcher Wert hat das Bauteil
из Поделиться
Thanks for showing it, had the same issue. It worked for a few days after cutting down the corroded part. Gonna try to replace the thermistor.
из Поделиться
Same issue, unfortunately the thermistor in my case was so badly corroded, that I was unable to solder back in. The humidity sensor (next to it) also showed values in the many 10s of MΩ range instead of the kΩ range.
None of the component has any indication of range.
In the end, I bypassed both components by a regular 10kΩ resistor until I can get some replacement part, this way it works (but lacking the safety features + settable humidity setting).
из Поделиться
Onde comprar peça completa?
из Поделиться
Hi, from your answers I realized that if the room temperature sensor is faulty, so I tried to evade it by blowing hot air into the appliance with a hair dryer and after a minute it started working again :)
Счет 1
voila la photo
Mise à jour (07/02/2018)
Voila la photo
Счет 0
33 Комментариев:
Bonsoir avez vous trouvez pour le réparer
из Поделиться
Bonjour non je n'arrive pas a démonter la face avant pour accéder au connecteur du capteur d'humidité
из Поделиться
il faut juste défaire les vis et après déboite le dur est au dessus prêt de la poignée
из Поделиться
pourriez vous me dire ou trouver un capteur d humidite car j ai fait tout les magasin a Charleroi et personne n en vend
из Поделиться
[image|1331830][image|1331827]
Voila les deux photos
из Поделиться
Показать ещё 28 комментариев
Does anyone know the value of that NTC thermistor? 10,50,100K?????
What is resistance at 20 or 25 degrees C????
Счет 0
3 Комментариев:
Bonjour je ne parle que le Français excuse moi de ne pas vous repondre
из Поделиться
bonjour le thermistor est a cote du capteur d humidite
из Поделиться
Did you ever find out the specs required for the little pinhead thermistor?
base resistance at x °C ? etc.
из Поделиться
Bonjour valeur de la thermistor?
NTC, PTC, 100K, 50K, 10K...?
Счет 0
1 Комментарий:
Bonjour je ne sais pas lire sa valeur
из Поделиться
Hello — Thermistor 10K ok — temperatuur 125 .. 250 ° ?? — Thankx ,François
Счет 0
1 Комментарий:
base resistance at x °C ? etc. 10k works you said, but did the appliance function properly afterwards?
из Поделиться
Résolu pour moi:
J’ai eu le même problème, je l’ai résolu en refaisant toutes les soudures du module capteur y compris celles du connecteur (c’était d’ailleurs celles la qui étaient mauvaises), le capteur thermique est NTC valeur à 20° environ 500 ohms et le capteur d’humidité semble être un modèle capacitif (je ne suis pas vraiment sure)
Счет 0
My board is completely corrosive, I'll have to clean it up well. How should I disconnect this 4 cables ? Thanks
Счет 0
Добавьте свой ответ
dulebu буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 35
За последние 30 дней: 122
За все время: 26,436
