Самая последняя версия серии Coolpix, Nikon Coolpix S5300, была анонсирована в январе 2014 года. Ремонт этого устройства аналогичен предыдущим моделям и потребует таких инструментов, как отвертка и пластиковый инструмент для открывания корпуса.
How do you replace a cracked screen?
My camera screen is cracked and I can't see my pictures, is there an easy and cost effective way to replace it?
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
If your camera screen is cracked and is affecting the functionality of the camera, or you simply wish you replace it, follow our simple replacement guide: LCD Screen Replacement Guide
Был ли этот ответ полезен?
Счет 0
5 Комментариев:
Please do not link to content that does not yet exists, or is not publicly accessible.
из
@flyingdutchman these are student assignments and they are (most likely) still working on that guide. If you click on both OP and Riordan McCole and Rebecca Field's profile you will notice that they are both in the same program. Confusing but pretty common and the guide will eventually appear.
из
when i go to the the link above, says "you cannot view this guide"--why not ?
из
@kbroo these are student assignments and they are (most likely) still working on that guide. The guide will eventually appear.
из
I'm down voting this answer because it's of no use without the guide and it has not been posted in a timely manner. Riordan gets an F from me on his assignment.
из
Добавьте свой ответ
Rebecca Field буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 24
За всё время: 459
