Дата выпуска: октябрь 2015 г. Номер модели: M4C63UA.
Can I exchange the RAM?
HP Stream x360 11 -p010nr
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
The laptop only has OnBoard 2GB of RAM; which means you cant switch it out.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
After going into the system information from the startup menu it shows that there are 2 dimm slots; does this not mean you can upgrade it? if you still cant, how come there would be 2 slots with only 1 in use?
из Поделиться
They make a Pro version of this laptop with 4gb of ram which uses 2gb in both "slots" both chips are however soldered on board i own a similar version of this laptop and have purchased another one with a broken screen for cheap my intention is to de-solder the chip and re-solder onto the working laptops mainboard in addition to this i have also got a m.2 connector which i will solder on to the secondary board to improve the hdd capacity by using a m.2 hdd it would be much more feasible to buy a laptop with better storage options and a larger ram capacity i am curious to see if this will work because this is a decent little laptop with decent battery life and a good build quality the only things lacking are the ram and storage space. i will post a guide on here if i am successful
из Поделиться
Добавьте свой ответ
Levante Anderson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 27
За все время: 1,351
