Упрощенная и более бюджетная версия чипсета XFX 680.
RAID 0 gone bad.
any ideas to get a raid 0 array working again? the drives are fine and all the data is on them, but raid doesn't want to recognize them. someone suggested rtools, but a demo version only lets you recover 64kb files. key? other options?
Это хороший вопрос?
Счет 1
1 Комментарий
did I mention this is for an XFX board?
read: running Windows 7.
из Поделиться
Добавить комментарий
1 ответ
Выбранное решение
If the RAID set is broken, yet you can read the data, your best option is to copy off what you can/need.
The only way I know to get a broken RAID 0 set back working is to set it up as new - which means the existing data is going to be erased.
RAID 0 is all about speed and performance - there is NO data redundancy... Depending on how your RAID controller and RAID 0 set was created, you may only lose files split across the drives (JBOD mode). If your RAID 0 was in Striped mode, you will probably need pay for something like rtools.
Был ли этот ответ полезен?
Счет 1
3 Комментариев:
that's what I figured, I'm trying to decide if rtools is worth it because I don't actually remember what's on them. If I knew, I'd be able to decide. Oh you, impasse!
из Поделиться
из Поделиться
R-Studio is a great thing. You will certainly be able to use it for other things beside this problem.
из Поделиться
Добавьте свой ответ
tabormeister буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 5
За последние 30 дней: 25
За все время: 4,875
