How to change cpu and gpu?
how to change my lenovo g 50 cpu and gpu?
Это хороший вопрос?
You can not change the CPU and GPU in this laptop....
Был ли этот ответ полезен?
If these are diagnosed faulty, they can be replaced with exactly same models using specialised soldering equipment, however they are most likely non-upgradeable due to high firmware and BIOS integration.
CPU and GPU in this laptop are fixed , hence you cannot change them.
I suggest attempting to reset the cmos on the motherboard via a jumper labeled pwr cmos, power jumper or just plainly, a big shiny flat yet round coin style battery. There are lots of tutorials on that topic with more info than I care to share here. Good luck!
And how is this related to the question?
If you are limited by firmware settings and bios settings you can reset the cmos in order to bypass them. Then you could try a different chip. Sorry, I’m tired.
In other words, reset the cmos by taking the button cell battery out.
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 16
За все время: 2,068
