Информация об устройстве и ремонте 60-дюймового HD-телевизора Samsung, выпущенного в 2013 году, номер модели UN60FH6003FXZA.
Back light dark on top
Dark the top is black
Это хороший вопрос?
Счет 2
6 Комментариев
@duba is it just darker or is it black? do you still see things on that part of the screen?
из
I have the same problem, my screen is dark in the top.
из
I have a similar problem but I have no image or sound it just blinks now on and off and the top of the tv is darker then the bottom I replaced the power board and the main board and still no fix need any tips!
из
I have the same problem. it started gradually getting worse now to the point the top is virtually un-viewable with the darkest at the top fading back to normal at the bottom. there is three cards in the back, has to be one of them i would think.
из
@georgesl not necessarily. Could be the LED strip that makes up your backlight. Repairable by disassembling the panel itself and hopefully getting an LED replacement
из
Показать ещё 1 комментарий
Добавить комментарий
1 ответ
Выбранное решение
@dube @lintaum this is most likely caused by a failed backlight. Could be the power board, the LCD or the inverter circuitry. This is a vague answer due to the fact that we do not have all the information.
Был ли этот ответ полезен?
Счет 3
Добавьте свой ответ
Portia буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 12
За всё время: 4,643
