ZTE Grand X Max — это 6-дюймовый смартфон от компании ZTE, выпущенный в октябре 2014 года.
I cant make calls
It won't let me make phone calls it hangs up tight away
Это хороший вопрос?
Счет 10
14 Комментариев
We need more information. Have you tried turn it off and again (not "sleep/suspend mode," but really powering down)? Have you changed anything recently? Does this happen with all local numbers? Finally, have you tried a factory reset to default state and tried again?
из
I have this problem as well, and I have done everything including a factory reset and still I have this issue. Perhaps a software flaw or something?
из
Same problem makes no sound when dialing and then lists at bottom can not complete because of unspecified error. Many incomming calls go direct to voice mail when the signal is very good. Sometimes can not get to retrieve voicemail. It seams to have no pattern as to when it will not work. I have not been able to call any number for the past day (error caon not complete). 05/17/2017 by sehappraiser@gmail.com
из
I wonder whats wrong ive done nothing else could make calls eariler
из
I couldn't call out, I had tried everything. After 2 30 minute phone calls to Tracfone and doing everything they suggested, still would not call out. When I saw the comment above about putting the phone back to factory setting I tried that and now my phone calls out. I was ready to buy a new phone.
из
Показать ещё 9 комментариев
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Had the same problem. Try turning off assisted dialing in call settings.
Hope this helped.
Был ли этот ответ полезен?
Счет 1
4 Комментариев:
Changed setting "Voice over LTE preferred " to off.
Fixed my ZTE Z799VL
To get to call settings (in android 6.0.1) select phone, dialer, and click on the 3 vertical dots on the left side of the text field of numbers.
из
I don't understand
из
Same ph though
из
I turned off everything I could find and now it works.
из
I put mine back to factory settings and haven't had a problem since. I wrote down my contacts first.
Счет 0
I'm not able to receive calls or call out from my zte phone
Счет 0
1 Комментарий:
No able to make calls or receive calls from my zte
из
Добавьте свой ответ
Jessica Jamaica буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 30
За всё время: 17,756
