Цифровая зеркальная фотокамера Nikon D600 с 24,3-мегапиксельной CMOS-матрицей формата FX
How do I open this ZIF? Connector?
Hi,
This is the underside of top of my D600 that I dropped. To mend the top display I had to remove this board and do some soldering.
I pulled out the ribbon that goes into the white connector at the bottom of the board as you view it - see attached photos.
I pushed back the ribbon, although it did no go completely in. After re-assembling the camera I found the wheel under the forefinger inperative.
How do I unlock this, I have so far not tried too hard as I must not break it!
hope someone can help,
John
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
every zif connectors have a plastic lock on it, just unlock with a small flat screw driver and pull out the ribbon cable carefully, when reconnecting extreme care should be taken.
Был ли этот ответ полезен?
Счет 0
The black part of the connector is the part that flips up to release the ribbon cable. Still be gentle with it.
Счет 0
Добавьте свой ответ
John Bishop буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 10
За последние 30 дней: 32
За всё время: 948
