Controller Port 1 doesent work
Hey Everyone,
I got a Dreamcast from Ebay, but the Controllerport A/1 doesent work. All the other, B/C/D works perfectly.
I hope you can help me
Это хороший вопрос?
Hey Everyone,
Это хороший вопрос?
This guide would be the easiest, if you don't want to solder it
Замена разъема контроллера Sega Dreamcast
This guide would use a little more work, but you could individually change out one controller port
Замена порта контроллера Sega Dreamcast
Also found this on eBay
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 24
За все время: 1,885
3 Комментариев
Do you know how to solder? If you don't, your best bet will be to purchase a replacement controller board off ebay and simply swap out the part.
из Ben Eccles Поделиться
yes i can solder, but why?
i read a lot of the problem on the internet, but that is always all controller prots, not only one. so i think the problme withe the fuse coulnd't be
из thunderblrd Поделиться
The reason I ask is that controller port board on the Dreamcast is among one of the more friendly parts for soldering, since all the components are through-hole. I would do a continuity test on the fuse, just to rule it out as a problem.
