Экономичная версия смартфона Samsung Galaxy S4, выпущенная в июле 2013 года.
Why can I get no network access
Hi, having just repaired an s4 mini, which is locked to EE, I've put my normal EE sim card in the phone, but get no network access at all. When the sim is in my other Samsung, there is a good signal. Does anyone have any ideas what the problem could be? I can save contacts to the sim card, so I think the sim reader is ok. Could it be an antenna? or is there another part that could be at fault.
Many thanks
Это хороший вопрос?
Счет 1
6 Комментариев
Are you on the stock software?
из
Hi Ethan, yes. Standard software.
из
By no network access, do you mean that you don't get a signal, or it gives you an error when trying to call someone
из
Actually both. Circle with a line through it at the top of the screen. If I try to make a call I get a message saying there is no network connection.
из
Hmm do you have all the required antennas properly inserted?
из
Показать ещё 1 комментарий
Добавить комментарий
1 ответ
Выбранное решение
Hey Bigphilly71,
I would recommend you contacting your provider, maybe they can help you! Also, check your motherboard if everything looks alright.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Bigphilly71 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 15
За всё время: 797
