Samsung NX30 — это беззеркальная камера со сменным объективом. Она поддерживает видео высокой четкости (HD) и была выпущена 18 февраля 2014 года.
Lens will not focus
Hi!
I got this camera three months ago and very satisfied with picture quality. Recently, I noticed that 55 mm lens that came with the camera stopped focusing. It will focus only on 45 mm, but not on 18mm. I tried changing settings from manual focus and back. Took the lens off and put it back.
Thanks,
Maria
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Maria, I have had a similar problem (with a different camera/lens). I have noted two possible causes. First is in low light or low contrast. It seems that especially with low contrast, it depends on having a focal length that includes enough variation in contrast in the auto focus region. Two ways to potentially handle this. Once you have found a focal length you can focus at, hold the shutter down 1/2 way down, then change the focal length of the lens. OR - change the AF focus method to, say, center weighting.
The other thing I have noticed is sometimes the battery indicator say everything is okay, but it is not sufficient for focusing under these low light/contrast conditions. Changing/recharging the battery has often resolved the problem.
Hope it helps.
Mike
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
mashahunter буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 37
За все время: 636
