Ноутбук Gateway модели NV77H33u — это портативный компьютер производства Gateway, поступивший в продажу в ноябре 2012 года.
Why is the screen dark?
My computer is fully charged and it's on, but the screen is black. I can see and move the mouse though. How do I get it to come back on?
Это хороший вопрос?
Счет 3
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Assuming you have already tried to adjust the brightness.
You may have a LCD power supply fault.
It is common with laptops that, if you can still see things on the screen with it being very dull the screen is not getting the correct power it requires to illuminate LCD.
Был ли этот ответ полезен?
Счет 2
Why is my screen is still off when I turned on the power?
Счет 1
1 Комментарий:
Hi @comfsm ,
Try booting with an external monitor connected.
If the desktop doesn't show on it either then you either have a faulty GPU or a faulty motherboard in the laptop.
If it does show OK on the external monitor shine a torch held at an angle close to the LCD screen of the laptop to see if the desktop is "visible"on it. If it is you have a "backlight " problem, which may be caused by either a faulty lid switch (or lid switch connection), a faulty video cable -or connection at either end - or a faulty LCD screen.
If there is nothing "visible" when using a torch light then it is either a faulty video cable, a faulty video cable connection at either end or a faulty LCD screen.
из
Добавьте свой ответ
Carson Jane буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 18
За всё время: 1,770
