Информация по ремонту и устранению неполадок для HP Pavilion dv6000, ноутбука HP, входящего в серию HP Pavilion. Выпущен в апреле 2007 года.
Display is completely black
I have an HP Pavilion dv6000 and from yesterday the PC has restarted, but the screen remains completely black, why?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
@piero90 connect an external monitor and let us know if that dispalys. This series laptop had issues with the GPU so the problem may be the logic board.
Был ли этот ответ полезен?
Счет 2
6 Комментариев:
If I connect a external monitor the PC functions.
из Поделиться
In that case consider replacing the LCD. Use these guides HP Pavilion dv6000 for that
из Поделиться
I have the same problem but mine dose not work with external display
из Поделиться
I had same issues with HP laptops and fixed it also owned dv6000 once the solution to this is quite strange but not a permanent and 100 percent sure although it worked for me every time especially with HP with AMD processors, cover up your laptop with blanket and start up let the exhaust choke up and due to excessive heat there are some micro ( solder ) joints fix's up and you will get your display back running . I was amazed how it worked for me and I took a risk after researching alot, I have fixed couple of other HP laptops with this technical glitch please be careful you don't burn out the beds. Hope it works for you.
из Поделиться
@chris7up " heat there are some micro ( solder ) joints fix's up " no system will heat up enough to fix any solder joints. The reason why this works temporarily at best, is related to the solder bumps with this poor processor design.
из Поделиться
Показать ещё 1 комментарий
Добавьте свой ответ
Piero Sabino буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 22
За все время: 537
