Why will my Camera not work
When I start up my camera the LCD screen is blinking with a code saying ER R but the shutter still works
Это хороший вопрос?
Это хороший вопрос?
Usually, on a Nikon D80 with an "err" message that won't go away, the Aperture Control Unit must be repaired or replaced. There is a small switch contact held on by a small plastic rivet in the Aperture Control Unit that tells the electronics module in the camera what phase the camera is in during its cocking cycle. When that small plastic rivet breaks, the camera can't determine where it is in the cycle and just stops and displays the "err" message.
There are 2 ways of fixing the problem, replacing the part with the same weak, plastic-riveted switch contact or taking the Aperture Control Unit apart and replacing the plastic rivet with a small steel screw which can't break again. I've been using the second method for many years now and haven't had a single body experience the same problem again.
Bob Kilbourn
Был ли этот ответ полезен?
so i looked at the control module and i cant seem to find the rivet where in the aperture control module could this rivet be found
За последние 24 часов: 1
За последние 7 дней: 11
За последние 30 дней: 38
За все время: 2,674
