Why is my audio not working?
I am trying to listen to music on my notebook but no luck. There is an error, it reads that there is another program using the audio.
Это хороший вопрос?
Счет 2
Добавить комментарий
3 Ответов
Выбранное решение
The IBM ThinkPad X41 has built in speakers, which can make audio problems frustrating. Try taking plugging in a pair of headphones into you laptop's headphone jack. If you hear sound in the headphones, then the problem could be a hardware problem. If you do not hear sound in the headphones, try one or more of the following:
  • Check your physical volume controls which are located at the top of the keyboard. using these controls, make sure that your volume settings are turned up.
  • Click on the speaker icon on your task bar in Windows to open the volume controls. Make sure that the Main volume control is turned up, and the volume is not set to mute.
  • If the above does not solve the problem, open the Device Manager by clicking the "Start Button", Control Panel, System, and then Maintenance. Then click on Sound, Video and Game Controllers. Check to see if there is a sound card detected.
  • If there is no sound card detected, the right click on My Computer and then select Properties. The click on the Hardware tab. After opening the Hardware tab, click on the the Device Manager button. In the device manager window click on the "+" sign next to Sign, Video, and Game Controllers. Then right click the time with the red icon and then select "Enable".
If this does not solve your problem, then a driver for the sound card may need to be reinstalled.
Был ли этот ответ полезен?
Счет 3
They're fixes that have helped other druggies resolve the Lenovo laptop no sound issue. Just work your way down the list until the problem is resolved.
You can start troubleshooting the laptop with no sound issue by following steps:
* Make sure to check your speaker and headphone connections for loose lines or the wrong jack.
* Try connecting your speaker or headphone device to a different harborage and see if this fixes the problem.
* Make sure the volume is audible
* occasionally you can’t hear sound from your speakers simply because the volume is mute or set too low.
To make sure the volume is audible
  • Click the sound icon on the lower-right of your screen, and also move the volume slider to at least half-up. However, make sure to slide the volume bar to an audible position too, If there’s a volume control on the app you’re playing.
* Still, make sure to slide the volume bar to an audible position too, If there’s a volume control on the app you’re playing.
  • Test if you can hear any sound from your Lenovo laptop.
Set dereliction audio bias
Immaculately, when a new audio device is fitted, Windows will automatically set it as the dereliction audio playback device. But that’s not always the case and occasionally we’ll have to set dereliction bias manually.
  • Right-click on the sound icon on the lower-right of your computer screen, and also click Sounds.
  • In the Playback tab, click on the audio device you wish to play, and also click Set dereliction. Click OK.
  • If the audio device you’re to play doesn’t show up in the device list and right-click on the space and tick Show Disabled bias. also right- click on the device once it appears and clicks Enable before you do step 2).
  • Check to see if your Lenovo no sound problem has been fixed.
Disable audio advancements
Audio advancements, as the name suggests, are features that allow for the loftiest sound dedication from your tackle. But depending on your configuration, they can also intrude on your system and detector sound problems. So we should disable audio advancements to see if it fixes the no sound on laptop problem.
  1. Right-click on the sound icon on the lower-right of your computer screen, and also click Sounds.
  2. In the Playback tab, right-click on your dereliction audio device and click Properties.
  3. Click the Enhancements tab, also tick the box for Disable all advancements and click OK.
  4. Test your audio device and see if the no sound issue is resolved.
Счет 2
Whenever you are unable to get the sound on lenovo computer. please install the earphone or speakers into your laptop. and then try to play something. lenovo laptop internal speakers not working but headphones are, please make these changes into your computer.
  1. Please make sure the driver for internal speakers are properly installed. if not, install the audio driver again.
  2. update the audio driver.
  3. Check the speakers wire. may be they are not attached on the motherboard properly.
  4. Update the windows too.
  5. Reset the computer.
After that if lenovo laptop has no sound, you need to visit the lenovo store for more help.
Счет 0
Добавьте свой ответ
Magaly Espinoza буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 25
За всё время: 1,839
