Первое поколение Honda CR-V, выпускавшееся с 1995 по 2001 год.
Fuel pump needs replacing.
My car is running but hesitates when I give it gas, then it surges. I believe it is the fuel pump. Would like to do it myself. Is it really difficult?
Это хороший вопрос?
Счет 1
1 Комментарий
I would check for vacuum leaks before condemning the fuel pump.
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
@paintmarrow not to complicated. Here are the instructions:
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Disconnecting the car battery before replacing the fuel pump is also a good idea.
из
Check EGR and gas filter
Счет 0
1 Комментарий:
Did the replacing the fuel pump work?
из
So i have a 01 honda crv… when i turn car on it idels crazy. Then sometimes my rpm gage will work sometimes not. It stoped working when i tried to give my car gas. It was stuffering like it was trying to shut off as i was going down road. Sometimes it will die when i come to a stop. I gave to put it in neutral and keep foot on gas. Then there are days she runs great . Put in new filter. And a idle air control sensor. And its still doing it. It didnt start this until i got timming belt done. The shop has looked at it and its not because of the timming .. so please help what could it
Счет 0
Добавьте свой ответ
Tamara Rose буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 15
За все время: 2,122
