Why is vacuum overheated
My stops working for a once a while them starts again almost like it overheating
Это хороший вопрос?
Это хороший вопрос?
dougcarrol, Dyson v6 shuts off like it may be over heating, could be Dysons thermal cut out. Found this info. at the Dyson link below, Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. May happen because the filters need cleaned/washing, machine could be plugged/blocked, floor brush roller seized from debri/hair wrapped around brush. Unplug, check filters, check for blockages, clean brush so it spins easy. Check the links below for more info. and instruction. Also note Dysons contact link, as I was informed they can also answer any questions you may have on their products. Good luck.
https://www.dyson.co.uk/support/dc24/dc2...
Был ли этот ответ полезен?
I found the already posted answer helpful but felt like a little room for more information on the complete troubleshooting, hope it helps.
Reasons for Dyson Overheating & Cutting out:
Solutions to Fix Overheating:
I have added the source as a hyperlink in the first heading, I actually tried briefing the answer concisely here and cutting the fluff. Well, I'm glad it helped me fix mine by resetting the thermal fuse.
За последние 24 часов: 1
За последние 7 дней: 20
За последние 30 дней: 152
За всё время: 46,621
2 Комментариев
Charge battery over night, turn on to vacuum , runs maybe 30 seconds , shuts off , put on charger for approx, 5 minutes ,works great ????
из stevecameronbimmernut
The best thing to check is isolating a blockage or airflow hinderance.
Take all the parts of. Including the full bin off the motor and the back filter from the motor. Now all you have is the motor and handle, run the motor. If it doesn’t shut off then it’s a blockage. If it shuts off it’s probably a motor fault.
Mine worked after a replacement back filter, you can get them on Amazon cheap. But make sure it also has good airflow. I also cleaned out the small hole in the bin that sucks in dust, this often gets blocked. Then the base roller thing often gets clogged too.
из richard hayward
