Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
How can I repair/replace the jack input?
I damaged my jack input by tripping over the cable, and now I only have the left side of the stereo. I'd like to replace the jack input or to repair it, maybe with a soldering iron.
Thanks !
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
You can replace the headphone jack, your challenge will be the soldering and locating the part. If you have a hot air station, you could replace it fairly easily. It's also possible with a good soldering iron, flux, and a solder sucker or wick.
If you're comfortable with the soldering part, you still need to locate the part. You can either look on aliexpress, as they have some headphone jacks listed for the XPS 13, or you could look on eBay for a XPS 13 motherboard thats broken, and transfer the headphone jack from that board.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Malo Herry буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 11
За всё время: 765
