Этот нетбук, выпущенный компанией Acer Inc. в июле 2008 года, относится к семейству Acer Aspire One ZG5 и имеет номер модели A150-1672.
My computer is frozen and unresponsive.
Randomly my computer froze and the mouse won't move on screen. I can't pull up the task manager or get anything to happen. When I press the power button, it will go to a black screen, but when I hit it again, it comes back to the same frozen screen.
Это хороший вопрос?
Счет 2
2 Комментариев
student question
из
My CP is stuck frozen how do I get it unfrozen
из
Добавить комментарий
4 Ответов
Выбранное решение
The computer may be taking in too much input or there could be a malfunctioning program or application.
Since you can't restart the computer on-screen, the best way to fix this is to do a hard reset by either holding down the power button until the computer totally shuts off, or by removing the battery.
After this, it may also be good to do a system restore to a time before your computer froze to make sure that there weren't any changes to your computer that caused the freeze.
Был ли этот ответ полезен?
Счет 1
My pc doesnt work when i turn it on my mouse doesnt move on screen restart it and the pc is still frozen please whoever fixes this I need help.
Thank You
Счет 1
1 Комментарий:
What if its a new one without a battery?
из
Remove the battery if you can, and if the device has a CMOS battery, remove that for 10 seconds. Replace both.
If you still get the same results, you may want to try replacing the hard drive, as I see this as a plausible reason for these symptoms.
Счет 0
2 Комментариев:
How do I for sure get it unstuck
из
This is a new CP how can the hard drive be bad
из
Control + Alt + Delete and restart.
I’ve had this problem a couple of times, but this always fixes it.
Счет 0
Добавьте свой ответ
Connor Watkins буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 11
За последние 30 дней: 37
За всё время: 28,299
